  • 2.3L (N/A & Turbo) Tech
WANT MORE POWER!
  • Thread starter Thread starter Aftermath
  • Start date Start date Mar 28, 2009
A
Aftermath
  • Mar 28, 2009
hi i just bought a 93 Mustang LX with a 4 in it. i am not the best when it comes to cars other people are in my family lol but i want to put a new engine in to it to go fast lol and i have been looking at a lot of forums and it seems to drop a 5.0 in there is just tuns of money is there a way to do so but keep a good budget i am willing to spend but i am young with a family lol well hope you guys can help
D
dreamer1uk
33
  • Mar 28, 2009
Hi,
Cheapest way of more power is to drop in a 2.3 Turbo engine from a SVO or a TC. You would need the a sutiable ECU like the LA3, wiring harness (or re pin yours), FMIC and a few other things.
Theres plenty of write ups on that swap on other Mustang forums out there.
Good luck!
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Mar 30, 2009
  • Mar 30, 2009
For the sake of us who do have SVOs......don't use one as a donor. The Merkur and Turbo Coupe people get cranky when those cars are suggested as donors, but at least there are still a lot more of them than the SVOs. I partly blame this "cannibalism" on the 2.3 being such a rotten engine for trying to get NA power out of.
That said, probably the most cost-effective way to get more than the factory rated power out of a '93 2.3NA is to pull it out and replace it with a 2.3T. Another option might be a late '90s 2.5 from a Ranger. I don't know what the nuances of a swap would be, but I do know that it's a dual plug/mass air/EDIS engine and it actually is a decent for being NA. There is also the more project-oriented Duratec, but conversion bellhousings are not cheap.
4turboho
119
  • Mar 31, 2009
just buy a wrecked 5.0l mustang and you got everything you need there.... buy a gasket set and replace all the gaskets and maybe have the heads done....if you want change the bearings and and rings and if you didnt do anything else CHANGE THE OILE PUMP!!lol Thats what i did on my first mustang if you have the donor car there is nothing else you need....thats my 2 cents
oh and its very straight forward i think the only thing i had to do was change th position of the cross member...theres tons of forums how to do the swap
65ShelbyClone
4,675
38
119
Apr 1, 2009
  • Apr 1, 2009
The 5.0 swap can't really be done right without a whole donor car. The k-member, front brakes, transmission, and rear end are all different(mostly better) on an '87-93 5.0. Most of the info on doing it is in the 5.0 Tech forum.
Jax Rhapsody
65
Louisville,KY
Apr 13, 2009
  • Apr 13, 2009
2.3 and 5.0 cars use the same Kmember. only V6 and L6 use different ones. Aeronose cars 2.3s use almost all v8 parts such as brakes. Thats all I'll tell you.
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
Which SN95 axles for 93 LX, disc brakes, ABS rings?
  • dan50
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 3, 2026
7-UP BILL
A
Procharger install/prep questions
  • ahratrew
  • Nov 22, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Nov 26, 2025
N
Fox Street Suspension Build Advice
  • NYFox
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
J
Wheels-Tires Need Some Help - Brakes Upgrade/Wheel fitment
  • jaygee15
  • Dec 8, 2025
  • 3 4 5
3K
Fox 5.0 Mustang Tech May 6, 2026
AeroCoupe
