Build Thread Want To Blow 5 Years And $50k On A Foxbody? Step By Step Instructions Inside!
Well, I knew I was going to run into my first major problem sooner or later. I just didn't expect it to be with the wheels. The rears don't fit. The tires stick out 1/4" past the fenders. Looks like we missed the mark on the backspacing. This is the first 9" wheel that True Forged has done on a fox with IRS, so we were kind of shooting from the hip as far as backspacing was concerned. I had the tires removed and the rear wheels will be going back on Monday. With the way the wheels are cut, there's no meat left on the hub pads to mill them down. The center sections will need to be cut out of the hoops and new ones will need to be made. I need a whole 1/2" additional backspacing, which is huge as far as wheels are concerned. Hopefully this change doesn't bankrupt me.
That does suck man, but when you get them back and they fit correctly, maybe you can share the final specs with everyone here so guys like me know exactly what fits best. It's good that you found out now though and not when it was the last thing to go on and keep you from driving it.
I used a backspacing measuring tool. Apparently it was a lying POS. However, the number I got was only 1/10" more than what TF was recommending, so I went with it. I don't expect them to fix it for free, but hopefully they are willing to work with me.
I gotta say that does suck.
Weird how we both had measurement related fk up's that ended in do-overs.
W/ me it was the axles,...and despite the fact that I measured the spacing between the wheels like I have done a million times before ,...this last time ended up w/ me paying 200.00 to have stock axles shortened to the point of them being unusable. I did get a pretty good break from Moser on the replacement hardened axles though,... maybe you'll get a similar break from your wheel supplier.
