Want to use AFR 205's and hydr. roller cam?
moneypit94
1,723
Macomb, IL
This may seem like a dumb question but AFR 205's are setup for a sollid roller cam. I have a 418 setup for a hydr. roller cam. What would it take to get these heads to work with a hydr. cam? Just a different set of springs or something?
Well i guess i should ask would it be worth it to convert the heads or just get new lifters and stuff?
Im looking to make this a semi streetable engine. Don't want to mess with adjusting valves all the time. Ideally looking for around 500 rwhp NA or 6-700 rwhp with a blower. Right now i have a complete 418 with tfs heads, TFS r intake, and an X cam... Looking to swap all of those out with AFR 205's, probe spyder intake, and a FTI cam... But ED said that those heads are for solid roller cam.
You can order your 205's from AFR with spring's rated up to .600 lift instead of the .670's which I believe is what come with them. I run 205's on my 408 with Comp's 288 Xtreme Energy Hyd. Roller Cam, and I used there new Bee Hive Spring's and Titanium Retainer's. The bee hives are ultra light and bring the max RPM of the hyd. roller cam to around 6300 RPM. Or you can just swap the AFR spring's with whatever Comp recomend's for the cam you select. Whatever you do, because of the high flow rates of the 205's you are going to want a pretty decent cam to get the most out of your stroker.
Thanks a lot 408
By chance how much does a set of spring run? Would the springs on it be worth anything, to sell that is? Im getting these heads for 1450 plus shipping... They are new and completed by AFR.. That is if nobody outbids me.. (anybody feel free to bid)
My setup sounds like it will be a lot like yours except for the who EFI thing... Have you had many problems? Right now I have a 69, block that has been deck plate bored, forged crank and h-beam rods and hyp. pistons. Im getting ready to swap the crappy pistons out. I am trying to decide if i want to go supercharged or now. I have an S-trim.. But most people say i should go NA with this one?
The spring's that come std. with the 205's are pretty extreme and woudn't be to hard to sell for a decent price. I'm in Canada so I'm not going to make any dollar figures as they don't compare to the US. Like I said above, go with the bee hive spring's. I sold the spring's that came with my 205's and I called Comp and they gave me the Bee Hive Spring Number that would best match my cam. If you don't want to spend big cash go with the steel retainers, as you will still have a light valvetrain, but if you don't mind spending an extra 100 for the titanium retainer's go for it as it is one hell of a light setup. You will need to buy spring locator's from comp as well for the bee hive's but they are cheap anyhow.
I just finished my 408 not long ago, so I'm still in the take it easy a bit break in process, but it run's like you woudn't believe. Using the lower deck height 69' Block involved shaving the SRP piston's a hair, but it was very minor. Otherwise it was an easy build and I havn't had no problem's yet. It make's awesome power all the way from 2000RPM to 6300RPM. I would definetly get rid of those Hyper. piston's you have though, and put some good forged unit's in there. There's nothing wrong with a supercharger, but I have alway's liked some good NA Horsepower (Big Compression, Big Cam etc.) That's your call though.
It doesn't matter now.. I got outbid and don't feel like going any higher on the heads. But im looking into the new Jeg's/Kaase heads.. 1640 for a completed set for hydro roller lifter cam... I would have to buy differen't vavle covers and different pushrods... Deffenetly go NA with these bad boys... I think they would match up nicely with a spyder intake and 10:1 compression. I just have to see how many rpms i can go safely.
I have do some more research on them though.
