TC have a limited slip differential and 3.55 gears or 3.73's... all you have to do is swap your axles and put your brakes on it. Only downfall is the Quad shocks won't work unless you remove the tack welds off the bracket and move them (i just removed the bracket completely. 5lbs) Cheap way of having gears.
I know where there are 3 well was 3 turbocuopes with the rearends still under them. 2 had 3:73 I know and one had 3:55. They were located in PoplarBluff ,Missouri. One at a salvage yard called A to Z, and one at Berry's Slavage and there were 1 or 2 at this one place I cant remeber the name but its on the main road its a body shop and he has them sitting out black one is black the other dark blue.
As said, if it's not an 8.8, I wouldn't waste the time and effort. You could always find a junked 8.8, and fill it with whatever you want. I wouldn't put a used rear in my car without going through it and replacing/checking bearings first.
The turbocoupe rearend is an 8.8 and comes factory wth either 3:55 gears with a standard or 3:73 with the auto, they had rear disc brakes also but they were 4 lug.
