  • 1994 - 1995 Specific Tech
Wanting to run boost
  • Thread starter Thread starter ga94gt
  • Start date Start date May 18, 2007
G
ga94gt
138
Ringgold GA
May 18, 2007
  • May 18, 2007
I am wanting to run about 6lbs of boost through a KB. My motor has 180,000 miles but it has good compression and runs stong. Or do I just need to rebuild the motor befor the KB. Keep in mind 6-7lbs of boost
Stanger007
2,015
Baton Rouge, LA
May 18, 2007
  • May 18, 2007
Rebuild now and at YOUR convenience. The lowend power of the KB is going to put a hurtin on your motor sooner or later.
Wes
G
ga94gt
138
Ringgold GA
May 19, 2007
  • May 19, 2007
any other suggestions?
Mustangless
903
home
May 19, 2007
  • May 19, 2007
You will probably end up wanting more than 6lbs. Anyways, you can put it on if you want, but just be prepared for the engine to go. It may last 100 miles, or 20k plus more. turbo5.0 or some name like that (multicolor car), had n20, vortech, kenne bell then a turbo. I think he was at 200k with those.
G
ga94gt
138
Ringgold GA
May 19, 2007
  • May 19, 2007
The car was lady driven, and since I have owned it I have only put 9,000 miles in 4 years. It is not my daily driver so that should no be to bad on it.
I will be putting new heads and cam and rocker before the KB.
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
393W Stroker with Boost - Need Spark Plug Recommendations
  • 387lx
  • Apr 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 30, 2026
HotFox
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Tuesday at 2:05 PM
Kleinjj27
K
L
5.4 4v base ignition timing table help.
  • leoleo
  • Aug 16, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 17, 2026
MustangBetts
M
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
