warning dinger
Are the ignition lock ears still attached to the lock (or do the ears spin around by themselves)?
Do your door pin switches work properly?
Worst case, you can pull the column cover and ignition lock (takes about 5 mins). Then you can access the wire going to the lock. If you disconnect it and insulate it, check and see if this circumvents the issue (you will no longer have the warning if you do leave your lights on however [and whatever else that warning chime does]).
Thanks Hissin50
The flange on the driver door pin was cracked which allowed to lay over a bit.
I hadden't noticed it before. Many thanks for the input!!
God Bless
and ride on!!
David:flag:
