- Nov 30, 2008
- 1
- 0
- 0
2001 Mustang V6
I have a milky white leak coming from the oil pressure sensor. Does the oil pump come in contact with any water? Where else could the water be mixing with my oil? I thought it was the head gaskets because there was a small amount of water in the oil so I replaced them about 2 weeks ago. The problem is getting worse and when the engine is running it runs out of the back of the sensor pretty quickly. I just wanted to see if anyone had any suggestions before I tear off the water pump timing chain cover and oil pump.
