water gauge Q.
I always use the stock locations. Theres really no reason to have 2 gauges for the same reading especially if you are using new gauges. The water temp is usually in the front of the intake manifold and the oil is somewhere on the block. Look for wires going to a sensor. An oil temp would work in the drain plug, it needs to be sitting in oil. An oil pressure gauge will not work in the pan.
