alright theres alittle water in my headlights, how can i get the water and condensation out of them? oh and there is small square of metal that fell of the top inside of the headlight and its just down in the bottom now, how do i get that out too?
pull the bulb use a wet/dry vac and hope the piece of metal will fit through hole plus it will pull water out.oh ya by the way if there cloudy clean them with alunimum wheel polish did wonders for mine.
You'll have to take the lights off and drain them out.... My aftermarket lights came with a drain tube attached to them in the upper corner of the lights. A drilled hole in the upper corner will work to vent out any water VAPOR the next time. A whole in the bottom will help to drain out liquid water also.
i tried and the metal piece wont fit through the whole, so how much would it be for new headlights without the bulbs? cuz i just bought new sylvania silver starts.
I have a set of used lamps, no backing plates or rubber seals that I will sell you for $30 plus shipping. They will need to be polished as someone mentioned earlier because they are cloudy.
If they are your original lamps I doubt they are worth saving. If you could get the lenses seperated from the reflector w/o cracking them {doubtful if they are 17 years old} you could fix the broken metal piece and then reseal them. PITA however! Then you would have cloudy, brittle 17 y.o. repaired lamps. Other than a crack the only place moisture can get in is the bulb o-ring or the lens to reflector seal.
Get new ones. You won't believe how much it will improve the looks of your car!
Yup, I had exactly the same problem with my off-shore ultra clear diamond cut lamps. The reflector never fell off but right after installation the LH fogged up. I was able to {since they were new} slice & gouge out the half-azzed glue they used to seal the lens to the reflector. I pulled them apart, scraped out all the original glue and resealed them with GE clear silicone. Clamped it together, let it dry overnight, reinstalled the next day. No leaks since then over a year ago. The RH side started the same thing about 2 weeks ago. Same procedure, no leaks/fogging since I did the same to it.
The Chinese lamps just don't have the quality to last like OEM Ford lamps do but if you want any style other than stock looking lamps, this is what you may have to put up with!
