  • SN95 4.6L Mustang Tech
water/methanol injection question
  • Thread starter Thread starter deftsound
  • Start date Start date Feb 17, 2006
deftsound
Please ask me how much my supercharger cost
Apr 6, 2004
945
Texas City TX
Feb 17, 2006
  • Feb 17, 2006
Can anyone explain to me what those water/methanol kits do?
Do they help build hp or something?
USMstang
114
Mississippi Gulf Coast
Feb 17, 2006
  • Feb 17, 2006
Water Injection Facts:
Water injection decreases the possibility of detonation by lowering the combustion chamber temperatures and increasing the effective "octane" of the fuel. This allows the engine to run a higher boost and full spark advance without the use of race gas. Additionally, if the water is atomized in the intake stream, there is an additional cooling of the intake charge. Both effects are increased with the inclusion of 50% alcohol to the mix (don't spray the exterior of an intercooler with alcohol!, this refers to internal injection only). The additional fuel of the high octane alcohol will in turn allow boost beyond what the factory fuel system can deliver.
Water injection also has the effect of "steam cleaning" the combustion chambers and exhaust valves. This removes the carbon build up that decreases efficiency and leads to pre-ignition(detonation). It will also keep the throttle body and interior of the intake manifold much cleaner than normal.
Water Injection FAQ:
Will water injection increase my horsepower?: Yes, but not directly. Water injection works to eliminate detonation, also known as knock. The big gains come from the ability to increase boost as well as the full ignition advance allowed by the ECU when it does not detect knock. While the cooling of the intake charge will produce some power increases, those increases are cancelled by the charge space occupied by the water vapor. In other words, there is slightly less room for air and fuel. However, by using up to 40 percent alcohol with the water, additional cooling takes place before the turbo, and the alcohol works as a fuel in the charge. This results in an increase in power.
Is water injection new?: No. Water injection was used during WWII to surpress detonation in fighter aircraft and increase their service ceiling.
Does the water "burn" in the engine?: No. The water simply converts from a vapor to a gaseous state which absorbs huge amounts of heat, due to the energy required to transform it.
USMstang
114
Feb 17, 2006
  • Feb 17, 2006
This product would obviously be most advantageous for the turbo or blown guys. I utilize it simply because after the initial cost (which is relatively low depending upon which brand you choose), water is cheaper than 93 octane gas for the predator tune.
Look around at some of the sites such as coolingmist.com or the snow site (maybe the same as boost cooler--can't remember) and for the do-it-yourself guys, go to
http://www.dawesdevices.com/water.html
where I plagarized the above explanation from.
Have fun!
coil pack bracket
  • SteveG94GT
  • Apr 11, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 11, 2026
SteveG94GT
Ignition Question
  • WantAn88GT
  • Sep 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
WantAn88GT
Fox Fuel injection questions
  • limp
  • Jul 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
