Water Pump Problems
  • Thread starter Thread starter FordGuy88
  • Start date Start date Jun 22, 2009
F
FordGuy88
241
Park Ridge, IL
Jun 22, 2009
  • Jun 22, 2009
The only accesories I am running on my fox is alternator and water pump. I also have an adjustable alternator bracket to get rid of the huge ugly stock tensioner and bracket. My belt is now on the opposite side of the pump pulley. So I need a water pump to spin the opposite way. I am going to stick with a mechanical pump too. Does anyone have any recomendations?
Thanks,
Dave
skunk21
1,203
Taxachusetts
Jun 22, 2009
  • Jun 22, 2009
any non h.o. 302 will be a standard rotation water pump. A water pump from a 85-90 crown vic fits, the problems is with any of these pump iirc is you will have to modify the bolt pattern to get it to fit, basically it's how they idiot proofed it so you wouldn't put a reverse pump into a standard pump car. I'm sure someone who has done a swap will chime in.
M
Mike in Texas
121
  • Jun 22, 2009
Water pump
Guys I'm confused. The specs show that my 1990 LX has a reverse rotation pump, outlet on drivers side. Is that wrong?
Maryland Stang
1,656
30
39
Greenville, NC
Jun 23, 2009
  • Jun 23, 2009
Nope. The outlet is on the driver's side and takes the large hose to the radiator also on the driver's side. Why are you confused?
F
FordGuy88
241
Park Ridge, IL
Jun 23, 2009
  • Jun 23, 2009
So which way is "reverse rotation" clockwise when your looking at the pulley? Is there any aftermarket pump that they make to solve this problem?
skunk21
1,203
Taxachusetts
Jun 23, 2009
  • Jun 23, 2009
reverse rotation water pumps run counter clockwise, if you change belt routing and get this type of pump running clockwise it will not cool for obvious reasons, the non h.o. 302's run a standard rotation water pump ( clockwise) like already stated. I don't know of an aftermarket pump, I'm thinking they don't do it for the reasons of ordering the wrong part# for a h.o. motor and getting a standard pump when they wanted a reverse pump and over heating he car , that's the reason for the different bolt patterns. you can search this though, plenty of people have switched pumps.
F
FordGuy88
241
Park Ridge, IL
Jun 23, 2009
  • Jun 23, 2009
Anyone done this swap? Or if anyone stumbles across the swap please post in here. Thanks everyone.
skunk21
1,203
Taxachusetts
Jun 23, 2009
  • Jun 23, 2009
http://forums.stangnet.com/781565-d...ater-pump-swap-now-having-cooling-issues.html
http://forums.stangnet.com/758446-any-harm-running-standard-rotation-wp.html
F
FordGuy88
241
Park Ridge, IL
Jun 23, 2009
  • Jun 23, 2009
Thank you very much. This is exactly what I was looking for.
M
Mike in Texas
121
#10
  • Jun 25, 2009
  • #10
Water pump
Now I got it, the reverse rotation (counter clockwise) is stock with the serpentine belt, when a direct drive belt is used the rotation is clockwise.
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
Engine Standard or hi flow water pump?
  • AnthonyA1234
  • Sep 28, 2026
Fox 5.0 Mustang Tech Oct 9, 2026
2000xp8
Idler pulley as substitute for Power Steering Pump ?
  • Bhenders
  • Jul 15, 2026
  • Other Auto Tech
Other Auto Tech Jul 16, 2026
LILCBRA
water pump pulley stock diameter
  • KAWMAN2
  • Jun 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 17, 2026
General karthief
coil pack bracket
  • SteveG94GT
  • Apr 11, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 11, 2026
SteveG94GT
