Water Pump Replacement Time
  • Thread starter Thread starter Jax
  • Start date Start date May 1, 2004
Jax
53
Massachusetts
May 1, 2004
  • May 1, 2004
Well, it looks like it might be time to replace the water pump. The pullies had been squealing, but then it stopped. Should have guessed it was just a matter of time, so now it is leaking at the bearing.
I'm thinking that "while i am at it" I should replace the hoses and maybe the radiator. Any suggestions for other things that should be done at the same time as the pump? How about better than stock water pumps?
Thanks for any thoughts,
Jax
D
D.Hearne
11,730
south louisiana
May 1, 2004
  • May 1, 2004
A little known fact about stock water pumps----- most applications had a high volume pump as an option. Check it out at you local parts house before buying a high dollar aftermarket pump that flows no more than the factory HV pumps did.
2nd Mustang
2,488
Southern California
May 2, 2004
  • May 2, 2004
I use a stock water pump on a warmed over 302, 160 degree themostat, flex fan, NO fan shroud and a 4 row radiator. It never gets over 190 degrees even on a hot summer day.
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Monday at 4:43 AM
manicmechanic007
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
O
2001 mustang gt overheating
  • orinsmiley11
  • Jul 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 17, 2025
