water pump replacement?
I'm at 58,000 miles with the stock water pump on a '95 GT and currently have all of the accessories unbolted from the engine. Should I put my stocker back on or look for a replacement as long as I have everything unbolted??????? It was running fine before and still is...but a few friends mentioned that as long as I have everything apart I should consider replacing it. Any experienced thoughts? Should I replace it now while it's easy to get to? Or is the stocker fairly reliable? It is 12+ years old now...... By the way, if you are recommending replacement, I'd like some ideas for water pump brands - i.e. stock Ford replacement, etc.
That water pump should have many more miles before needing to be replaced as my 95 has 93xxx and was just changed out. The only reason it was changed out is because I'm replacing everything and while the coolant was out for the radiator change I decided to replace it. Change it now will run you about $70.00 or later at the same $70.00 plus two hours of your time.
When you do get around to replacing it, the Stewart stage 1 brand pump is very nice. I've had two of them (the first one I screwed up, no fault of the pump, long story) and have been very pleased.
If you've got the extra cash and would rather be proactive on changing a part that WILL eventually fail (congrats on getting 12 yrs outta it) you can look at the Stewart pump here:
http://www.stewartcomponents.net/Me...ROD&Product_Code=16183&Category_Code=FordSTG1
http://store.summitracing.com/partd...319745+4294908331+4294924755+115&autoview=sku
Wes
I changed mine out at 129,000 miles and it was still working fine, I wouldn't worry about it at this point. I bought a genuine Ford replacement waterpump from Jegs for about 50 bucks, hell you can't even touch a rebuilt pump from a parts store for that money.
While I agree that 59k miles is very low, I would change it. I changed everything when I redid my h/c/i and motor, I mean everything, the only thing that got reused was my intake, and oil pan. It was cheap ins, to change all the little stuff, the last piece's I am going to change are the vaccuume lines.
Well
There certainly are more difficult jobs to do on our Stangs than swap
out a wp.
I'm kinda 50 50 on doing it while you got it apart :shrug:
however
I'd not do a cheapie ... low quality part :nono:
Like Wes ... I run a Stewart high volume wp :D
Very Nice Part ;)
Grady
