water pump?
  • Thread starter Thread starter nuggets
  • Start date Start date Oct 4, 2006
N
nuggets
9
siloam springs, arkansas
Oct 4, 2006
  • Oct 4, 2006
I started my car last night drove it for about 10 minutes and noticed my temp gauge was almost at 270 I turned on my heater and drove about a quarter mile till I could pull off the road, then the temp started dropping. When I got out I had water leaking from the hoses to the water pump. Checked my rad and it was a little low. I let it cool down started it and drove it home with the heater on and it ran cool the whole way. Any ideas? I put a new thermostat on it sunday.
Thanks for any responses
gcwh02
515
pottstown, PA
Oct 4, 2006
  • Oct 4, 2006
are the hoses on all the way? are there cracks in the hoses? In most cases when the pump goes, the coolant comes out the plug in the water pump. But if you caught it before it did that and the pump is broken I guess it could squeek out a weak hose. Check the hoses out and get back to us.
HISSIN50
34
129
Oct 4, 2006
  • Oct 4, 2006
To try to narrow it down a bit: when lookin at the weep hole at the bottom of the pump, you can often see the stains egressing the weep hole. The weeping lets you know that the pump has some bearing wear.
Good luck.
gcwh02
515
pottstown, PA
Oct 4, 2006
  • Oct 4, 2006
yea thats what I meant by the "plug" haha. I couldnt think of the word weep hole
bullitstang1313
713
Indianapolis / Columbus, Indiana
Oct 5, 2006
  • Oct 5, 2006
Did you let the engine run with the radiator cap off to purge out all of the air when you replaced the thermostat? How low was the coolant or did you notice any leaks when you got home and it was running cool?
Engine Standard or hi flow water pump?
  • AnthonyA1234
  • Sep 28, 2026
Fox 5.0 Mustang Tech Oct 9, 2026
2000xp8
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
