88 Crown Vic is std rotation, same setup I have on my 89 V8 Ranger. Uses a flat serpentine style belt, one for the P/S, W/P and Alt. The other belt ran the A/C and smog pump. The timing cover is cast with the ports opposite the rev. rotation one, so the rev rotation pump won't fit. There are at least three pumps available for it. Two are cast iron, one is std volume, the other high volume (this is the Police & Taxi or extra cooling pump) The late 88's used a std volume aluminum pump. At least one vendor makes an aluminum "high performance" pump (don't recall the vendor but I got it from Autozone) thats a low volume, high rpm pump (bad for the street)
