Michael Yount said:I wish I could remember the mag article - I read just the other day on electric vs. mechanical. They freed up on the order of 8-10HP at peak. However, that's not the whole story. First, you need to be sure that you have enough alternator to manage the load. And you need to understand where the application makes sense, and where it doesn't. The electric pumps don't flow at peak anywhere near what the mechanical pumps do at high engine rpm. So, for example, on a road race application, a mechanical pump will move a lot more water than an electric pump will. However, on the street, where most time is spent at low rpm - the electric may move more water than the mechanical since it's output is not dependant on engine speed. Also, for autocross and drag applications, the pump can be run independantly to cool down things between runs.
If you decide to go that route, two thoughts. First - use this to control your pump - www.dccontrol.com. One unit can be used to control both pump and electric fans varying current and speed to both minimizing current load and unit speed. Second, get the parts needed to rebuild the unit - cause if you have a failure, you're not gonna find repair parts at your local parts place.
Michael Yount said:As for the cost/performance benefit, only you can decide. But for what it's gonna cost to put the elec. pump on, you could almost put a nice nitrous shot on it. MUCH bigger bang for the buck.....just a thought.
I want to build it all motor strong, but have a shot for an extra punch.Michael Yount said:Since it's primarily a racer, weight is probably the most important thing - and contrary to popular myth, light weight is the alum. radiator's single advantage. For the same size, number of rows and fins/inch, a copper core transfers more heat than an aluminum core. But in the size you're talking about, either will have more than enough capacity, and the copper unit is much heavier.
Michael Yount said:EMW - I'd use the variable current/speed controler on the pump, and simply toggle the 'trigger' wire on the controller to shut it off while racing. For street use, it will sense temps. at the t'stat housing, and hold them constant to within 3F +/- provided you have the radiator/fan to remove the heat from the engine.
Michael Yount said:Ask the same question of Brian too - he's got a lot of experience driving different fans/pumps with it -- maybe even more than the pump manufacturers have. My understanding is that it's actually EASIER for the motor because there's no startup current spike needed to get the motor going. Longer life for motor, alternator and battery by driving one variably and 'easing' into start up rather than cycling on/off at full warp speed. Not to mention you don't use anymore current than you have to which optimizes energy usage. Green race car - sort of....![]()
