Weatherstripping
  • Thread starter Thread starter Drew_Carroll
  • Start date Start date Apr 26, 2005
Drew_Carroll
22
  • Apr 26, 2005
Question: Is it hard to replace the weather stripping on door of a sweet, gorgeous Ford Mustang 5.0 (LX 1989). Do you just push it into place or is there a secret ford method passed through generation upon generation of ford enthuisiasts? america rules along with
rd
3,316
63
109
Ocean Springs MS
Apr 27, 2005
  • Apr 27, 2005
It is easy. Does take some time and patience. You have to remove the door sill plate, and unbolt the rear interior side panel , and the seatbelt anchor, to get the sidepanel loose.
The actual weatherstrip just pulls off, and pushes on. Clean the area while it is apart, push the new one on, make sure it seats into the corners, and trim it to get a nice joint at the bottom.
You may have to adjust the door strikers to get the doors to close afterwards.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 27, 2005
  • Apr 27, 2005
I put the joint at about 6" from the bottom of the doorsill on the front edge of the door frame. That keeps it out of the way so that it doesn't get knocked off getting in & out of the car.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Apr 27, 2005
  • Apr 27, 2005
Making it join at the bottom of the door seal is also good because as water is affected by gravity or wind it isn't going to come through the door.
The old weatherstripping will just pull off (it is attached by a rubber cement type glue)...you then just press in the new weatherstripping evenly. The kit will come (the one from 50resto.com) with excess slack so you can get it how you like it. Cut it cleanly off (it has a aluminum type plate in it so scissors don't work the best). I tap it around with a hammer to ensure proper seating...and you will notice your doors pop open faster when you open the doors open especially when it is new. It isn't all padded down...
Henceforward
The Avatar Master
485
  • Apr 27, 2005
I totalled up the cost of weather stripping for my 1992 Vert. using the CJponyparts, and 50resto catalogs...
With ALL new seals on everything, (Windshield, doors, convertible top pieces, etc...) the total came out to be more than $400, forget that. I can deal with the rain if it rains at all.
I wish there was a package deal for around $200.
Drew_Carroll
22
  • Apr 27, 2005
Damn, 400 bucks?!??! I say just wear a poncho
J
  • JRC99
  • Apr 19, 2025
JRC99
J
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Engine New to Mustangs, guidance needed on fault codes 47 & 45
  • sUdz6.0pwrstk
  • Sep 30, 2021
4K
Fox 5.0 Mustang Tech Oct 23, 2021
General karthief
Price?
  • Blueinfan
  • May 27, 2022
  • What is it Worth?!?!?
5K
What is it Worth?!?!? May 30, 2022
7991LXnSHO
For Sale 193 Original Miles on this RARE Barn Find 1989 Ford Mustang LX 5.0 Convertible
  • EarnhartBuilt
  • Dec 16, 2019
8K
Fox Body Mustangs For Sale (1979-93) Jul 27, 2023
Blueinfan
