weight reduction help
  • Thread starter Thread starter gcwh02
  • Start date Start date Mar 10, 2008
gcwh02
515
pottstown, PA
Mar 10, 2008
  • Mar 10, 2008
im looking to unbolt a bunch of things and need some help/opinions. I hear about deleting brake booster, evap something? Are those things ok to delete? Also, which fender is the cruise control located at?
J
Jmood
169
Arkansaw
Mar 10, 2008
  • Mar 10, 2008
cruise is in the drivers fender, and weighs a ton........brake booster delete will require some parts to purchase, I believe...
NKau
1,346
Jefferson, WI
Mar 10, 2008
  • Mar 10, 2008
GT foglight brackets supposedly weigh quite a bit. I don't care what they weigh; I wouldn't be removing my brake booster or working cruise control for any reason.
gcwh02
515
pottstown, PA
Mar 10, 2008
  • Mar 10, 2008
yea they are already off. I don't care about cruise control so thats going. Brake booster I would have to see what side effects there would be before that goes.
1990lx5oh
26
Weaverville, NC
Mar 10, 2008
  • Mar 10, 2008
Really stiff brakes. Probably will be stiffer than manual brakes.
bloopbloob
578
Alberta
Mar 10, 2008
  • Mar 10, 2008
evap box (charcoal cannister) doesn't weigh that much, i wouldn't recommend removing it if you park in an enclosed space. it keeps gas fumes from your tank from venting into the atmosphere. it's located on the passenger side fender near the smog pump though..... just a little black box with a couple lines running into it...
what about a/c, smog pump, bigger stuff like that?
88mouse
630
Mooresville nc
Mar 10, 2008
  • Mar 10, 2008
If you delete the brake booster, you need to put a big bore master cyl. on it. I did this on my 71 road runner and the brakes on it are easier to push than the power brakes.
Turkey Sammich
I can't fap normal. I cracked a rib, then my ankle
Jul 12, 2006
154
Mar 10, 2008
  • Mar 10, 2008
Could always take out the backseat, there's another 12lbs.
I believe the a/c delete was around 22lbs.
Sicarius428
2,085
Mar 11, 2008
  • Mar 11, 2008
Keep your brake booster. Brakes and steering are two things you don't want to give up... especially on these things. You will need all the brakes and steering you can get. The dogbone on the rear axle is dead weight. Some say it helps dampen vibration but given that you would give up your brakes, Dogbone might be a better option. Fog light brackets, AC system, Smog system depending on your laws, rear seats, stereo(speakers are magnets)... I am not sure how far you want to go with this.
Kevin
gcwh02
515
pottstown, PA
Mar 11, 2008
#10
  • Mar 11, 2008
  • #10
k evap and brake booster are staying. I removed a/c and smog already, just thinking of other things
gcwh02
515
pottstown, PA
Mar 11, 2008
#11
  • Mar 11, 2008
  • #11
Kevin
yea i think the dogbone is gonna go
Sicarius428
2,085
Mar 11, 2008
#12
  • Mar 11, 2008
  • #12
There are side impact braces in the door that weigh a ton. You can cut them out and maybe weld some tubular ones in. I have seen a tubular front and rear bumper which will reduce a bit a weight but I don't know how safe these are in an accident. Are you planning on spending some money to reduce the weight or just trying to strip the car. Is this your daily driver or pretty much a track car? I would suggest Aluminium heads. Takes about 40-50 lbs off the front tires but that will cost you a grand easy. Sound deadening, trunk carpet. Relocate your battery to the trunk will offset the weight which is almost as good as removing it.
Kevin
gcwh02
515
pottstown, PA
Mar 11, 2008
#13
  • Mar 11, 2008
  • #13
Kevin
It's my street/strip car... yea im actually waiting for that tubular front bumper to come in the mail haha, I did the sound deadening, the trunk carpet, relocated battery, no smog,no a/c, fog lights and bracket, metal brackets under my rear interior panels, racing seats, fiberglass hood, no hood latch equipment, alum d/s, welds with skinnies, alum. rad., removed front swaybar.. thats all i can think of. But I'm trying to make up for the weight added by my 6 pt.
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Wednesday at 9:17 AM
keel
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Saturday at 8:51 AM
Rdub6
M
2001 evap/heater core questions
  • mnky99
  • Sep 3, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 3, 2025
mnky99
M
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
