what would be the cheapest..least appearance affecting...and most effective way to pull some weight off of my 95 gt?
BlueOvalStangGT said:rear spoiler weighs 11 pounds, dog bone 9, all of the smog equipment weighs approx 11. im going to go weigh my seats cause i think its alot more then 37 pounds. my car weighs in a 3200 with 1/2 tank of gas
95snoozer said:8- these brackets that are behind the rear wheels. its a rubber wedge with pipes
95snoozer said:aluminum heads expect 48+ pounds weight savings
Why does it matter how fat someone is to you? So there is no use making a mustang lighter because someone is fat... that makes a lotta senseBlack95GTS said:I'm with snoozer... I was up at Epping NH a year or so ago and this guy talking about how much weight he had dropped from his camaro. The dude was like 5'10 260. Stop hittin the cupcakes after the strip and you're talkin minimum 60 pound weight reduction. How many fat Nascar drivers are there?
. Im fat and thats just more reason to make my car lighter weight94DreamGT said:OK...I'm not trying to flame you here as I believe there is some very good weight reduction ideas in your post, but some of your weights are off.
For instance:
Man...I sure hope you're not referring to these:
I too had "heard" that by removing these you could save 5lbs or so. Well...I got under there back behind the rear tire and removed them. Hmmm...they sure feel light. I weighed them on an accurate scale and guess what...they were not even ONE POUND EACH!!! No way 8lbs. Also...they were packed full of dirt, so if I had cleaned them up, we're talking very light, just some plastic that is basically hollow.
Also:
My FULLY ASSEMBLED AFR's, which are about the lightest aluminum heads you can get, were about 27lbs each. Fully assembled stock E7's are about 44lbs each. That's about 34lbs savings, not 48+, you're about 15lbs too much there.
I won't touch upon everything as there were others, but be carefuly what you hear and don't just "assume". Some are very good weight savings, others are not even worth taking out.
Some people worry too much about taking out a pound here or there when there is an easy 40lb or 50lbs they can take off by doing one thing...a DIET
Like I said, good information in your post and I"m not trying to make you look bad...there was just some errors.
