Weird Beeping Sound
I have a 92 GT Convertible and when i started it up this morning to go to work, it started making a random beeping sound that sounds like it's coming from under the dash. I already know that it is not the door buzzer, but it is very similar with a higher pitch and is a lot louder. Everything in the car works and it runs fine. Any help is appreciated and thanks in advance.:shrug:
It's coming from the air bag module. It does this when the air bag light burns out. Listen to the beeps as it's trying to "flash" to code to you. Either replace the bulb or fix the problem. Mine is doing the same thing right now. But it's not my DD so I just deal with it.
No. Pop the ac switch bezel off and unscrew the four screws. Unplug switches and 2/3 screws holding the switches on and move to the side. You might get away with just pulling the radio out. I took mine out when I had the dash out so Im not certain on this though.
