Weird Blinker problem
Kabuki_notch
657
360
113
Rochester, NY
so a couple days ago my car started this weird issue, When I start the car I would get the blinker noise for about 1min then it would stop. this is without touching the turning signal switch. then I would drive, and then use the signal and the "clicking" noise would not go away for about a min again. It seems to periodically start up on it's own. has anyone seen anything like this? Thanks in advance.
-Rob
There is probably remnants of an old alarm system in there. In that case, you'd be hearing the parking-light flash relay clicking.
Get the relay to click like it does when you go to start the car and trace it by sound.
Good luck.
