Ok I know all about the hanging idle problem, I still have yet to check my TPS. I adjusted the screw on my throttle body and lowered my timing a bit which did help a lot.
When im driving around and shift at like 2,700 or above when I put in the clutch my RPMS shoot up about 500rpm or mabye a bit more untill i get in it gear again then it drops right down. When I come to stop signs it sits at like 1,000rpm then goes down to 800 or so.
Ok the weird part that confuses me. I noticed it seems to hang up around 1,000 after I put it in neutral when im stoping at a light as soon as I put in the clutch to put it into Neutral it goes to 1,000+ and sits there, but I noticed IT SITS THERE UNTILL I COME TO A COMPLETE STOP then like 3 seconds later it drops down. SOOO I tested it, I went to a long hill, crusing in 3rd I put her in neutral, the rpms go down but still hang at 1,000 like usual, I coast for a good 15 seconds but there still haning, come to the stop sign then 3 seconds or so later they drop down.
DOES THAT SOUND LIKE A NORMAL HANING IDLE PROBLEM? What could this be!!?
ps: I have H/C/I, TB, and all the usual boltons.
