weird head bolt question
  • Thread starter Thread starter njoliver
  • Start date Start date Jan 15, 2010
N
njoliver
259
Columbus OH
Jan 15, 2010
  • Jan 15, 2010
alright this isnt a 5.0 question but it is a general engine question I think. I bought a truck for real cheap with a freshly rebuilt 350 in it. There is white assembly grease coming out of the head bolts ( outside ones). I dont know if they are backing off or what? Any one ever have this before? should I just torque them? Any help would be appreciated thanks
71 blown vert
Toronto, Ontario
Jan 15, 2010
  • Jan 15, 2010
Does it smell like coolant? Lower bolt holes need to be sealed and if not they can leak or if its a very small leak it can foam a little and thicken up. Just a guess though.
SpartaPerformance
2,517
61
89
Long Island NY
Jan 15, 2010
  • Jan 15, 2010
I've never used or seen or heard of anyone using assembly lube on head bolts. I'ld make sure it's not some kind of coolant or oil foaming up. You can try torqueing them and see what happens.
rainman38501
cookeville tn
Jan 16, 2010
  • Jan 16, 2010
head bolts
anytime you have a bolt that the threads go into coolant passages you will use a sealer on the threads!this is common in engine building but most people never see it if it is done properly! not enough and you have leaks, too much and you have a white mess!
N
njoliver
259
Columbus OH
Jan 16, 2010
  • Jan 16, 2010
it is like thick white grease, it doesnt smell or look like coolant. I can wipe it off and it comes back out? I never this happen before but I have been finding alot of wierd things with this engine
M
mr_josh
87
Jan 16, 2010
  • Jan 16, 2010
If it's coming back out, you've almost certainly got oil mixing with coolant. Hate to say it but I'd immediately pull those heads, check that they're true, and then bolt them back on with sealant on the right bolts.
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
Milton Questions, 351 swap newedge
  • 996stang
  • Jul 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 25, 2026
Killer351w
K
CFI to carb conversion question
  • StockerStang
  • Mar 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 11, 2025
AeroCoupe
