Weird idle Problem
1BAD89GT
87
Oklahoma
Weird idle problem just started friday night when pulling up to a light and just leaving in 1st gear with clutch pressed in idle wont come down below 1300rpms,But if i pull the stick into neutral and let off clutch pedal it will Idle normally at 900rpms.first time ive seen this problem driving me nuts.
Yea, I would check your tps voltage. A friend of mine (redhot91gt's) car does this also (it is a 5 speed). In addition, mine would hang at 1,200 rpm i neutral and then come down to normal idle rpm.
Let me know what happens. Good luck.
Should be at .98 Right?
Egr Sensor
I had the idle bug for a while. It was bad every other redlight or slow down it was idling up and down. So, I replaced and set the tps to .97 to .99. I cleaned the IAC. I replaced the egr sensor. I cleaned he EGR valve with wd40 or some other cleaner. (worked the egr back and forth with screwdriver). It fixed it by about 90 to 95%.
