So, I'm driving to work as usual. All of a sudden, the car won't accelerate. I press the gas pedal, nothing happens. The car is decelerating slowly, the rpm's are dropping slowly as well, but I don't have a check engine light. I pop the tranny in neutral and try to start the car, but it won't restart. I turn the ignition to off, then try to start the engine, nothing. It turns over, but won't start. By the time I'm at around 20mph, power steering is out and the rpm's are nearly gone. Once the rpm's drop below 400 or so, the engine finally dies.
Once the engine dies, THEN I can restart the car. It restarts right away and I drive off as if nothing happened. This happened Thursday on the way home, and then this morning. It happened maybe twice in the past year, but that's it. I've checked for codes, but haven't been able to read any.
The fuel pressure regulator is new and hasn't given me any issues so far. I'm not leaking any fuel, and the engine runs smooth otherwise. Is my fuel pump going out, or is there something else I can check?
