Weird starting behavior
  • Thread starter Thread starter Paladin0027
  • Start date Start date Dec 29, 2009
Paladin0027
  • Dec 29, 2009
Hey guys if anyone could shed some light on this situation it would be most appreciated. I had a 2002 GT 5 spd coupe and just recently bought a 2001 GT auto vert. Both seem to have the same behavior when starting, seems every 5th time or so that i start the engine it doesnt seem to ignite. It will turn over and start you just have to hold the key down for a second or two longer than normal. Sounds like a peice of crap when that happens. Any ways to remedy that?
streethorse
1,042
Dallas Texas
Dec 29, 2009
  • Dec 29, 2009
A weak or near death battery would be the first thing to rule out.
Then check the spark plug condition, If not motorcraft, replace.
And change out the fuel filter. Then go from there if it still isnt right.
Black'02
100
Rochester, NY
Dec 30, 2009
  • Dec 30, 2009
I think its a fairly common problem. I think people tend to see it more often when the engine is hot. Mine does the same thing and as of yet i haven't heard anyone give an actual cause/solution to the problem. I live with it, but it can be kind of embarassing sometimes.
40oz
499
Minneapolis
Dec 30, 2009
  • Dec 30, 2009
turn the key on and leave it while you buckle your seat belt and get ready to drive. That lets the fuel pump run and pressure the sytetm before you try to turn it over. Mine rarely balks at starting, but I'd agree that it's only when hot that it ever does it. And it never takes more than a second turn on the first firing for it to start and run.
Obviously you don't remember having to let the starter turn the engine over ten or twenty times to start a car. Nobody thought you had a POS in that case. They were floored when your car started on the first or second spin every time. That was a sign of a well-tuned car. Having to turn the key a second time was only after holding it for a minute of failure. And that was not unusual on a cold day. A third time was normal for most people.
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
Crank no start, I’m stumped!
  • Seth Brogan
  • May 18, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 14, 2026
BossHorseGirl
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
