Weird starting problem...
  • Thread starter Thread starter mustangfb66
  • Start date Start date Mar 24, 2004
M
mustangfb66
45
Central California
Mar 24, 2004
  • Mar 24, 2004
My friends dad has a '68 CA special. It has a 289 w/ a C4. But they can't get it to run right. Right now it will run (barely) on 4 cylinders. What is happening is that only half of the distributor is getting spark. All the cylinders that are firing, are together on the distributor cap. So for some reason only half of the distributor is getting spark. The car has a new cap and rotor, and I belive new points as well.
Any ideas as to what could cause this?
Thanks,
Efren
67CoupeDriva
165
South Carolina
Mar 24, 2004
  • Mar 24, 2004
Sounds like voodoo to me.
No really, it kind of depends upon what the pattern is. You say only half the engine -- does that mean right vs. left (which would be REALLY odd), or just random cylinders?
Is the distributor original? Could the bearings be bad or the shaft warped enough to miss half the distributor cap (again, look for a pattern). Are the new cap and rotor good quality (I'm sure you've looked, but no plastic flashing obstructing good contact). Is the metal strip on top that contacts the coil straight or could it be contacting intermittantly?
Is the timing right Possible that a new cam or old timing set have caused the engine to be off (my old set slipped a couple of teeth, but it would not run at all). Are the plugs and wires new and/or good? Stupid question but are you SURE there is NO spark, and not just a weak/intermittant/badly timed one?
That's a lot to look at but it sounds like an odd problem.
dodgestang
1,360
Cecil County, MD
Mar 24, 2004
  • Mar 24, 2004
Have you ensured that the cap is wired with the correct firing order?
T
toyshop
28
  • Mar 24, 2004
Thanks,
Efren
Quite possibly the dist shaft could be bent (somehow). Seriously, hook up a timing light to each cylinder (one at a time obviously) and make sure you do not have secondary voltage. (spark) If you do not in fact have secondary voltage, then there is something in the primary causing the secondary to not be triggered ( like the dist shaft being bent and not opening the points?) Good luck. Hope you get er going soon.
68GEETEE
5 Year Member
Nov 21, 2003
481
Texas, USA
Mar 24, 2004
  • Mar 24, 2004
Did they do some work to the motor recently? I would think either the cam is not degreed in correctly, or maybe they installed the distributor without the #1 cylinder at TDC. Just a thought.
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 11, 2026
roldy
R
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
96 GT 4.6 w/ dirty spark plug well
  • Mustang Momma
  • Apr 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 9, 2026
LILCBRA
