weird throttle or gas flow problem
bluidvl
63
delaware
when i step on the gas it kinda flutters a bit in all gears i have all new injectors,thinking fuel pump but not sure please help.it does not do it at wot,just at low speeds.anyone ever have this problem.
I agree, not a fuel problem. You might also check your timing, might not be advanced enough to come off idle nice. Also what's your setup like? I've seen engines with too much induction on top of stock heads stumble a bit. They catch a big breath of air and the heads cause a bottleneck. They usually run ok through mid and top end.
this sucks cause i just got car back from shop what a nightmare that was hade to take car .needless to say the shop sucked and i was turned on to it by local speed shop dont know what they did but it didn't do it before it went there.
went from 75mm tb to 65 when i did that it started to idle funny tried to adjust tps but could not get it right.after 2 months yes 2 months in shop and several.things don like egr delete.new injectors,new distributor,i started thinking mass air well turns out resistor was bad. that was a 75mm for 19lb injectors.they replaced with new stock ford mass air.that was the last thing they checked after i said something to them .needless to say i got ripped off!!!!!!!!!!!!!!!!!!!!!!!!!
When you say you couldn't get the TPS right I don't quite follow you, you set it by voltage. Are you saying that the voltage wouldn't stabilize while it sat at closed throttle? If so the TPS is bad or is there some other way that you are trying to set it?
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
