Weirdness with my timing (It's me again).
Ok re-cap. Did a headswap and now i just noticed something weird when she was running.
I did the ole' finger test. Told my dad to put his finger over the #1 cyl hole while i slowly crank over, when his finger pops off he gives me the yell and its at TDC.
I took a look at the balancer and it read an almost perfect 4 degrees advance (0 is TDC so im damn close). I drop the dizzy in with the rotor facing the 1 on the cap. I rotate the dizzy a tad clockwise just to make sure its advanced a couple more degrees before i start. I crank it over and she fires up, i check timing with spout out and it shows me 40 degrees. WTF? ive done this technique before and it works flawlessly. Why is my sh1t showing 40 degrees? Im pretty sure either the pointer or the computer is whack. Has this ever happened to you? BTW no pinging.
