welcome to the no fire help line HELP
bcd
274
arab al
I am just about finished with my four banger conversion. I was planning on cranking it yesterday, BUT I have no fire. Best I can tell there is fire going to the coil but none coming out. I tried the four banger coil the coil that came on the 5.0 and a new one from autozone. Still no fire. Can some one help me?????
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor
E.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/article...c-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
B.) Coil
C.) TFI module
H.) Computer
B.) Distributor cap
C.) Rotor
Two reasons:
A it is not so equipped.
B Tried three different coils.
C What is a TFI module
D Spark doesnt make it past coil.
E gonna try
F can you open those rubber fuse links
G it turns over, It lights the test light on one side of coil connector when unplugged and both sides at top of connector when plugged up.
H can you test the computer?
E gonna try
The TFI module is bolted to the distributor and fires the coil under computer control. The Pip sensor inside the distributor triggers the TFI.
Use a voltmeter for steps E, F, & G for best results. The fuse links connect to a yellow wire that connects to the battery side of the starter solenoid. They are inside the wiring harness, so you would have to split the harness open to examine the fuse links. Some clever use of a voltmeter will check them out without having to split the wiring harness open. Measure the voltage drop across the fuse links to determine if they are defective. There should be less than .5 volt drop across a fuse link.
See http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for wiring diagrams for you car.
Computer seldom die. Test for voltage at the coil & TPS before worrying about the computer.
Computer seldom die. Test for voltage at the coil & TPS before worrying about the computer.[/QUOTE
Are you talking about the ignition control module? The wires coming into the coil have power but the coil wire does not. So wouldn't that eliminate the ignition control and pip from my current problem? Thanks for your responses ,by the way.
The TFI provides a ground for the coil circuit. No ground, no fire the coil.
The diagram is from the Autozone site I referred to earlier
I put a new ignition control module on it. is there a way I can test to see if its the problem? I put a 95 cap and button on the car could that be the problem? (The motor came out of a 95 car)
The auto parts stores can test TFi mofules to a limited extent. Other than than make sure the battery is good & crank the car up normally.
Or...
Mark the distributor base to engine block mount with a scribe. Then loosen the distributor & turn the key switch to run. Twist the distributor and that will trigger the coil to fire. Realign the marks and tighten down the distributor when you are done.
Or...
Does that mean that if my timing is bad off the coil wont fire at all. Will the clutch have to be in for it to fire or will it be an automatic thing. What does that pip sensor look like? I bought the distributor off a wrecked car with out a module and put it on. I dont know if it had that thing in it. If that is the problem then I will feel like a jackA** ,but a happy jackA** if it cranks
Oh yeah. I took the coil wire off of the coil and tied a piece of 18 guage wire to it then layed it next to the strut to see if it would arc and nothing. Could it still be the things we have been talking about
The test method is another way to get the coil to spark if the starter doesn't work.
The pip sensor is the little plastic magnetic sensor in the bottom of the distributor that lives under the shutter wheel. It senses the openings in the shutter wheel and knows to fire the coil.
Is there a crank shaft position sensor. I put a 95 motor in the fox.
bullitstang1313 said:
Did you use the distributor and ignition module from the 95. The 94/95 mustangs had the ignition module mounted on the passenger side fender but the 87-93 mustangs had the ignition module mounted directly on the distributor.
I got a used fox distributor and new module. i am using the 94/95 cap and rotor.
bcd said:
Would it be because I dont have anything in the 02 plugs or the EGR plug?
No. Those will set codes, but will not prevent the engine from starting.
Go back to the no start checklist. Check one item at a time. If that item checks out good, go to the next item. That way you won't be chasing your own tail. If you follow the list you will find the problem. I have seen better than a 95% success rate using it to systematically find the problem.
well i guess i am going to get a remanufactured distributor today and retime the motor. does the pip sensor come in remanufactured distributors or would i have to buy one as well. i will eventually replace all the possiblities until it works. I hate trouble shooting.
well, i have a new distributor a new coil a new tfi module a new cap and button and it still doesn't fire. I guess I am going to have to push it out of the gerage and burn it.
Do you have 12 volts at the coil? Check the red/green wire for 12 volts using a voltmeter or DVM. Check it while cranking the engine.
