Weld 4.5 BS wheel Question
It is a good idea to upgrade your studs anyways. A racing set from moroso or arp are much strnger then the standard stud you have in your axle. I upgraded and installed longer studs. As already stated you do need a different style lug nut. The weld rims actually sit on the shaft of the lug nuts not the studs.
Yep, exactly what he said. I believe the studs are supposed to protrude through the wheel about a 1/2" in order to be NHRA legal. The stock studs actually sit about 1/16" - 1/8" below the face of the wheel.
