Weld through ceramic coatings??
  • Thread starter Thread starter p5.0ny
  • Start date Start date Aug 26, 2006
P
p5.0ny
133
Arnold, MO
Aug 26, 2006
  • Aug 26, 2006
Does anyboby know if you can weld through ceramic coating or does it have to be ground off?
The real question is on a pair of MAC LTs. If they are bolted up to the block and I cut some 3/8" steel to bridge between the tubes and welded it, would it work? Anybody try it. I can't be the first person with the idea. Would the coating bubble and pool in the weld?
Thanks
R
R2D2
Aug 26, 2006
  • Aug 26, 2006
wont work
RYC CUKR
1,437
Orlando
Aug 26, 2006
  • Aug 26, 2006
coating has to be ground down. You gotta have bare metal to weld to .
bluevenom867
I will have images of molesting stuffed animals in
Dec 15, 2003
1,704
St.Petersburg,FL
Aug 27, 2006
  • Aug 27, 2006
The exhaust shop was able to weld tabs onto our ceramic coated header collecter.I was also able to weld a small aera of the pipe to flange,and the enitre header is coated inside and out.As long as the work cable is is making a good connection,I think it will work.
BlooDReigN
283
Calgary, Alberta
Aug 27, 2006
  • Aug 27, 2006
I bet those are some strong welds you got there!
bluevenom867
Dec 15, 2003
1,704
St.Petersburg,FL
Aug 27, 2006
  • Aug 27, 2006
Actualy they are,%100 penitration at the flange to pipe joint and the tabs are very secure.
fastford91
254
Niagara ,Ontario, Canada
Aug 27, 2006
  • Aug 27, 2006
i am a welder by trade and you must take the coating off before trying to weld or all youll get is a huge mess and probably a usless part!! do it right and save time and money !!!
bluevenom867
Dec 15, 2003
1,704
St.Petersburg,FL
Aug 27, 2006
  • Aug 27, 2006
What kinda welder did you try it on?
I used a flux core type,so perhapse most of the molten ceramic ended up in the slag?
fastford91
254
Aug 28, 2006
  • Aug 28, 2006
ya some of your coating did end up in the slag but some of it also got mixed into the base metal creating a weak weld! i guarantee if you xrayed or ultrasound the weld it will show impurites and weak spots in the weld though not visable with the eye! they are there ! but it dosnt mean that they will break ! not yet anyway! but like i said do it right and save time and money! just a little grinding no big deal!!!
M
Jacking Rail
  • martroy
  • Oct 7, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 11, 2024
martroy
M
  • dan50
  • Jul 18, 2026
dan50
M
  • mnky99
  • Sep 5, 2025
mnky99
M
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
Fuel Fuel Pump Rewire, New Fuel Lines, and Installation of New Fuel Pump Hanger with AN6 Connections
  • AeroCoupe
  • Mar 12, 2023
14K
Fox 5.0 Mustang Tech Apr 16, 2023
AeroCoupe
