Welded Axles
  • Thread starter Thread starter hotstang_46
  • Start date Start date Sep 21, 2010
hotstang_46
481
Charlotte NC
Sep 21, 2010
  • Sep 21, 2010
So I'm thinking about getting a 00 saleen 281 that is making some power. It's a turbo car. The whole car is built except for a few things that I would do to it right away. One thing that came to mind is the rear end. With that type of power I would be thinking diff rear and axles may be mandatory. I know I ran into problems with just 460rwhp on my gt. But in the description the guy lists "welded axles". I guess I would ask why weld them? Does it increase durability or something? why would that have been done.
thanks
bhuff30
6,037
35
129
Olathe KS
Sep 21, 2010
  • Sep 21, 2010
Welded axles probably means the differential is welded together so the axles always turn together. The guy was obviously too cheap to even buy a spool. Anyway, you'd want to fix that if you want to drive it on the street.
N
ninjastang125
591
maryland
Sep 21, 2010
  • Sep 21, 2010
Maybe he was thinking welded axle tubes?
Maxpowers
859
Pittsburgh, Pa
Sep 21, 2010
  • Sep 21, 2010
This is what I think most people refer to when they say welded axles.
hotstang_46
481
Charlotte NC
Sep 21, 2010
  • Sep 21, 2010
I suppose I should have worded that better. It has "welded" axle tubes.
Flghtmstr1
572
Springfield, PA
Sep 22, 2010
  • Sep 22, 2010
The axle tubes in the 8.8 are just pressed in from the factory. Some people like to weld them to the pumpkin to prevent them from spinning / moving. I'd say that doing so can't hurt, but it's not enough to beef up the rear properly. Get some good 31-spline axles and a 31-spline carrier / differential of your choice (TrueTrac, Detroit Locker, or LSD) and you'll be fine.
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
New Products From J&M Products - 1979-1998 & 1999-2004 Race/Extreme Duty Rear Lower Control Arms
  • J&M Products
  • Oct 9, 2025
  • Vendor Sponsor Forums
Vendor Sponsor Forums Oct 9, 2025
J&M Products
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
