Welder Suggestions
  • Thread starter Thread starter sj9ers
  • Start date Start date Jan 31, 2009
sj9ers
71
  • Jan 31, 2009
I'm a college kid on a budget and need some suggestions on an affordable welder to buy for use on my mustang. This will be the first time I've ever welded and I wont be doing that big of jobs just filling in holes in the firewall and installing a floorpan and some other various projects. From researching I heard a MIG welder was the best and I've also read about flux wire welders that seam to be more affordable but I don't know if they will suit my needs. So wats a good inexpensive one to get me started? Keep in mind it doesn't have to last forever and I'm just trying to get started right now. Also I do have an arc welder that I got for free but never used and was wondering if that could be used on the projects I mentioned before?
Thanks
Evilfox
45
Elk Grove, Ca
Feb 1, 2009
  • Feb 1, 2009
If you want cheap then check out Harbor Freights MIG welders. I bought one in a pinch and it was alright. My only gripe is no matter what I did it left small BB's on everything that I had to wire-brush off.
Harbor Freight Tools
219.99 if you don't mind a slightly used one. $20 more for a new one.
Edit
When you upgrade I recommend a Lincoln Electric. I have a K2470-1 which I absolutely love. One will set you back just shy of 600 dollars though.
bentley429
Banned
Nov 25, 2004
528
Connecticut
Feb 1, 2009
  • Feb 1, 2009
Ours is a lincoln weld-pak 140 I believe. Real cheap at homo depot, does flux core or gas. Flux core is garbage. It is only 120v and works great for the little welder it is. Check them out.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,359
209
114
Ohio
Feb 3, 2009
  • Feb 3, 2009
Hobart Handler 140
millhouse
1,985
Simpsonville, SC
Feb 3, 2009
  • Feb 3, 2009
Shakerhood said:
Hobart Handler 140
X2
It's made by Miller and uses high quality components. Look for packages sold through Tractor Supply. I picked up my HH180 for ~ $600 including the tank, cart, auto darkening helmet, gloves, 2 spools of wire, a couple wire brushes and a few other misc. items. Not bad considering the welder itself was sitting next to the "managers special" package for nearly $650 by itself...and the helmet was nearly $150!!!!!
bynummustang
Seen my other Jackstand?
Jul 24, 2005
NC State University
Feb 3, 2009
  • Feb 3, 2009
"Buy nice or buy twice"
If you really want to do good work in a timely manner stay away from the harbor frieght welders. A buddy had one, and you could only burn for about 30 seconds. The duty cycle was very short. Which for you, might be a good idea so you don't weld too much at a time and warp the metal.
I don't mean to start a brand war, being that I haven't used a Lincoln much, but I've used the hell out of Miller stick and MIG welders, and I have no complaints. (except for the overhead fillet bead with a 6011 rod)
Oil choice for after break in period.
  • Sask84gt
  • Feb 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 14, 2026
Praetorious
P
Paint and Body Rotten moon roof trim
  • Teen'93stang5.0
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 15, 2026
Teen'93stang5.0
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech May 31, 2026
LILCBRA
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
