welding axle tubes and torque boxes
it's easiest to remove the whole rear-end for the job...gives you a lot more room.
Also, if you have a back seat in, you'll need to remove it along with some of that sound deadning material.
I had 5 or 6 wet towels that I layed across the inside of the car.
You should be able to remove the rear in about an hour.
I did it with the rear end out. Wasn't hard. For some of the larger gap welds in the torque boxes start by making large clean tacs, then welding from tac to tac slowly. This will also reduce heat stress, and the likely hood that your carpet will light on fire lol
I heard that the axle tubes couldn't be welded unless the differential was heated a certain way because the metal material is very hard to weld:shrug:
The problem is that with MIG you have to crank the voltage up alot to penetrate the diff housing, but when you do that you risk burning straight through the axle tubes. Using a small MAAP gas torch, or even a propane torch if thats all you have, to pre-heat the axle housing might help a bit. Big thing is go really, really slow. If I was do to it again I would have done the axles with a stick welder because it lays down such a wider bead, and penetration is pretty much uniform with a decent pool - either that or learn to TIG :nice:
I thought the housing was cast, if that is the case, than you will need to heat the housing. Cast metals are hard to weld correctly. Sure, you can lay a weld down, but if you improperly weld cast metal, than it could cause damage. The idea is to evenly heat the cast metal before you weld.
If the housing is not cast than just disregard the statement above.
Now I have a question. If you weld your axle tubes to the housing, would the heat of the weld hurt anything inside the housing such as grease or bearings?
