welding quick question...
  • Thread starter Thread starter cardude
  • Start date Start date Jun 27, 2005
cardude
221
Portland, OR
Jun 27, 2005
  • Jun 27, 2005
I have been practicing welding and okay at this point. I wanted to weld in a patch or two in the floor of my 66, and I wanted to double check disconnecting the battery. I remember reading in the past to disconnect the positive lead, does this mean I should keep the neg lead connected or does not matter?
dont want to zap my stuff if at all possible.
thanks
iskwezm
4,159
20
79
Rowland Heights,California
Jun 27, 2005
  • Jun 27, 2005
If you disconnect the positive,your battery isnt completing the "ciruit",you'll be fine.
bdavis
Ofallon MO
Jun 28, 2005
  • Jun 28, 2005
I've always heard of horror stories about this but I run a circle track dirt car and weld on it every week with out disconnecting anything. I have a 66 coupe I was welding on last night and did not disconnect any thing either?
Both cars have complete MSD 6al systems.
I just always hook my ground as close to my work as possible.
Not sure why some people have problems with this????? I must be lucky.
shotsy
233
Oklahoma City
Jun 28, 2005
  • Jun 28, 2005
Electricity will always take the path of least resistance, battery shouldnt come into play unless your welding right near it, but in the words of a wise old man an ounce of prevention is worth a pound of cure!!
oz
1,079
10
58
Plymouth, MI
Jun 29, 2005
  • Jun 29, 2005
yea, as long as the car is sitting on the tires, the electricity will flow between the welders ground wire and arc. The only time I would be concerned for the battery would be if there was a ground strap attached to the body somewhere between the welder ground and arc.
G
Intro and FB questions
  • gflat65
  • Nov 16, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 25, 2025
horse sence
C
1993 airbag module noise
  • Charlie1
  • Sep 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 21, 2025
Charlie1
C
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
Subframe connector question
  • B0udreaux
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 5, 2026
rednotch
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
