Well im stuck on my c&l intake install please help
trav_19
810
Jackson, MI
ok guys i forgot the name of the sensor in the elbow but its the only one that threads in, when i go to install it in my c&l i cant get it to thread in... its some cheap plastic sensor and it looks like its starting to mess up the threads, it looks like the begining of the tapped threads in the c&l are goofed up...so how do i fix this??? im getting pissed nothing on re-assembly is going smoothly at all. it looks like its soft is there a bolt or something i can try threading in to clean up the first row of threads?? any help is appreciated
sounds like you're talking about the ACT sensor that's before the MAF.
i don't know much, but i would definately say to put it where it belongs--if you screw up the threads, try siliconing it in place and make sure you get a good seal.
Trav, if this is a new piece, I'd contact the vendor/manufacturer - let them know the IAT (that's what it sounds like you're talkin about) wont thread in and you think the threads might be galled.
If not, Eric's got the right idea. I'd use a tapered tap.
Good luck.
Trav
Seems like I remember a good bit of peeps run the C&L stuff over on
the Corral.
If others have had similar issues with them ... then I'd say you should
clean up the threads and go on about life.
btw ... the act thread size is 3/8" NPT ;)
Grady
