mackey
SorsCode said:For the breakin period.. If its Roller Cam and you got 20 minutes run time its pretty much set in... Flat tappet I really recommend what you suggested but with Roller there usually set within 10 minutes of run time if that.
Actually you really do not need to run it for 10 minutes because it is in fact a roller cam. There is no break in of a flat tappet cam because it rolls around the cam. There is no metal shavings that are coming off the cam from the roller. If there are you have some serious problems. With my rollers I usually run it for 500 miles then change it.
