Well yesterday I took my car to the ford dealer to have the charging system fixed and to have it aligned and now I need some help. The service manager called and said "Have you had any problems with the engine because its blown ?" well I pulled it down last night and one of the exh. valves was bent by the piston. It doesnt look like the piston is hurt but I will be pulling the pan tonight and knocking it out to double check it and recheck all of the main & rod bolts. I called ford racing's technical line before I built it about the cam and 1.7 rockers and they said it will be close but should be ok. Obviously I will be rechecking those clearances and may have to switch to 1.6 rockers to keep the lift down some. I wonder also if having the engine sitting for 2 years not turned has weakend the valve springs? My question is if the rod is not the problem what would yall check.
