went to steeda for my bumpsteer kit today.....
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
and ended up leaving with a bit more.....sometimes i hate the fact that they are local.
Kudos for the bump steer kit, and control arms. The "adjustable" sway bar is a total joke IMO. I had one and sold it before I even put it on the car after getting a good look at it.
Good luck with the control arm install can be a PITA!
sage2k said:
whats a bumpsteer kit do?
When you put lowering springs in a car, you are also changing the steering geometry along with the suspension geometry. Adding a bumpsteer kit allows you to dial the steering back so that your tires won't try to turn a bit when your suspension travels (i.e. prevents a bump from steering your car).
Plus when you trash your tie rod ends when removing them off the spindle you'll need to replace them anyway. This is why I replaced mine. Figured it would be easier to align the car and correct the steering geometry also.
