went to the track last night
  • Thread starter Thread starter disturbdgt
  • Start date Start date Mar 22, 2008
1 of 2 Next Last
disturbdgt
90
suffolk, va
Mar 22, 2008
  • Mar 22, 2008
well last night i took the stang to the track. It was an 1/8th mile track. well it was my first time and i think i sucked pretty bad. i ran two times.
1st run= 9.44 sec @ 77mph
2nd run= 9.40 sec @ 78mph
I had the traction control on, probably should of took it off but wasnt for sure. My only mods are magnaflow magnapack catback, everything else is stock. So how do you guys think i did, i think i could of done better.
Black_02_GT
Mississippi
Mar 22, 2008
  • Mar 22, 2008
Leaving traction on is several tenths of a second added on to the time, so yes turn it off. My first time was a few weeks ago and best I got was a 9.5. I got it pulled down to a 9.2 last night.
disturbdgt
90
suffolk, va
Mar 22, 2008
  • Mar 22, 2008
ok so i guess next friday night i will just turn traction off. what were your mods?
Black_02_GT
Mississippi
Mar 22, 2008
  • Mar 22, 2008
o/r x pipe, set of flowmasters and a steeda short throw. I was running the kumho ecstas and i spun like a mofo in 2nd so it probably could have been slightly better
tank_567
731
26
29
Raleigh, Nc
Mar 22, 2008
  • Mar 22, 2008
You guys should be able to run low 9s in the 1/8 with some better 60fts I'm running 8.8s in my vert. Keep the traction control off
Black_02_GT
Mississippi
Mar 22, 2008
  • Mar 22, 2008
It's the tires i must say we were gonna throw some better tires on but i was like screw it, was my last run and i was ready to head to the house
J
justinschmidt1
349
  • Mar 22, 2008
the one with 270 whp?
shouldnt you be running 8.8s
joshheat25
871
Delaware
Mar 22, 2008
  • Mar 22, 2008
you should be running below 9 in teh 1/8
Black_02_GT
Mississippi
Mar 22, 2008
  • Mar 22, 2008
who???
tank_567
731
26
29
Raleigh, Nc
Mar 22, 2008
#10
  • Mar 22, 2008
  • #10
? I am running in the high 8s in the 1/8 mile
Green&GoldGT
302
Virginia
Mar 23, 2008
#11
  • Mar 23, 2008
  • #11
Good to see you went to the track. Which place did you go to?
disturbdgt
90
suffolk, va
Mar 23, 2008
#12
  • Mar 23, 2008
  • #12
i went to a track in hertford, nc
BurningRubber
1,865
24
58
Mar 23, 2008
#13
  • Mar 23, 2008
  • #13
Turn the TC off like everyone else said, practice getting out of the hole and have some fun!
My first time to the track was a 1/4 mile, I ran a 15.1... hahaha. Next run I ran a 14.9.
Next time I ran another 1/4 mile I ran a 13.9. Practice makes a big difference.
mazen189
424
I.E. southern california
Mar 23, 2008
#14
  • Mar 23, 2008
  • #14
F traction control.
J
justinschmidt1
349
#15
  • Mar 24, 2008
  • #15
you said this
it just seemed liked you were comparing like a stock car to them and saying they shold run atleast low 9s since you run 8.8s
but your car isnt stock and it makes 270 whp
tank_567
731
26
29
Raleigh, Nc
Mar 24, 2008
#16
  • Mar 24, 2008
  • #16
you said this
I was just trying to say my convertible was able to run sub 9s, it does weight a lot more than a coupe. So a coupe would be able to run a low 9 with less mods.
disturbdgt
90
suffolk, va
Mar 29, 2008
#17
  • Mar 29, 2008
  • #17
ok guys i have a quick question. well last night i went back to the track adn i did worse than i did last week.
1st run = 9.6x sec @ 76 mph.
I was talking to someone there at the track before i ran and he told me that i should lower my tire pressure down to like 15-20 psi. so i did so. (keep in mind im on street tires)
I also left traction control off and still did worse. so my question is what should i have my tire pressure at, cause last week i had it at like 30-35psi. and what do yall think could be the problem here, i will post up my 60' and rt when i get a chance.
Black_02_GT
Mississippi
Mar 29, 2008
#18
  • Mar 29, 2008
  • #18
last night @ 20 psi i was puttin down 9.2s again... and i still couldnt hook first off the line and after the eighth i dunno what was happening... i was losing so much time after that but my eighth stayed pretty consistent last night just wasnt my night at the track and who knows it might not have been yours either
What are you launching at?
disturbdgt
90
suffolk, va
Mar 29, 2008
#19
  • Mar 29, 2008
  • #19
yeah i guess not b/c everytime i ran last night my times were like 9.56, 9.6 or something around 9.6 and my mphs were close. so my times adn mph were consistent last night i just dont understand what was wrong.
Winters98GT
Whoop...whoop-whoop-whoop-whoop...GANGNAM STYLE!!!
1,291
224
H Town
Mar 29, 2008
#20
  • Mar 29, 2008
  • #20
Track prep has a lot to do with it. You will find that some people say lower your tire pressure on street tires, and others advise against it. I always lower my street tires to around 18psi.
Another key is learning to slip the clutch when launching. I used to cut sub 2.00's on street tires routinely, but that was on a good track. Last week, the best I could do was 2.2-2.3 sixty foots, slipping the clutch. Again, track prep and conditions have a lot to do with it. If you plan on going to the track, a set of drag radials should be at the top of your list of mods. Pick up a used set of 17 inch rims for 100-150 bucks and slap them on before you head out.
At 78mph, I think you should be around 8.8-8.9.
1 of 2 Next Last
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 11, 2026
02_2v_Curtis
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Electrical Innovate PSB-1 is DOA? Am I an idiot? All plausable. Please Help
  • Dontknowchit
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
Dontknowchit
