went to the track last night
  • Thread starter Thread starter disturbdgt
  • Start date Start date Mar 22, 2008
First Prev 2 of 2
Black_02_GT
Mississippi
Mar 29, 2008
#21
  • Mar 29, 2008
  • #21
Im gonna say experiment and try and try again, you'll know what works best on what nights and can optimize performance then...
Winters98GT
Whoop...whoop-whoop-whoop-whoop...GANGNAM STYLE!!!
1,291
224
H Town
Mar 29, 2008
#22
  • Mar 29, 2008
  • #22
If your running at the same track, ET's are going to be determined by Density Altitude, given that track prep is consistant. Get your sixty foot to a consistant 1.95-2.05 and then you can start to judge your performance. MPH is also a good indication, but a lot more factors you have to consider. MPH depends on Density Altitude, the weight of your car, and the amount of wheelspin you have off the line(60ft again), as well as some of other factors. 60ft is the name of the game, especially in the 1/8
Black_02_GT
Mississippi
Mar 29, 2008
#23
  • Mar 29, 2008
  • #23
i dunno if i said that right.. but my point being is try and try til you find what's right then practice. things always come out way different than i mean for them to.
Green&GoldGT
302
Virginia
Mar 30, 2008
#24
  • Mar 30, 2008
  • #24
what were your 60' times? Traction control should be off and drop your rear tire pressure to low 20's and your front tire pressure should be high to reduce rolling resistance. For your front tires, check your tires max pressure and fill it to about 5psi less. Practice slipping out the clutch on your launch.
SonicStangGT
146
King, North Carolina
Apr 3, 2008
#25
  • Apr 3, 2008
  • #25
A set of drag radials will amaze you. I run about 15 psi at the track on 315/35/17 mickey thompsons, and can pull constant 1.90 60's.
disturbdgt
90
suffolk, va
Apr 5, 2008
#26
  • Apr 5, 2008
  • #26
well went to the track last night and got some new times
1st run i ran a 9.175
2nd 9.40
3rd 9.3
i will get the mph's up and 60' also soon.
disturbdgt
90
suffolk, va
Apr 5, 2008
#27
  • Apr 5, 2008
  • #27
ok times
9.175sec @ 78mph w/ 2.173 (60')
9.318sec @ 77mph w/ 2.253 (60')
9.401sec @ 77mph w/ 2.326 (60')
BurningRubber
1,865
24
58
Apr 6, 2008
#28
  • Apr 6, 2008
  • #28
If you can bring your 60' down to a 2.0 or 1.9 you should see 9 flat or a high 8 pass.
First Prev 2 of 2
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 11, 2026
02_2v_Curtis
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Electrical Innovate PSB-1 is DOA? Am I an idiot? All plausable. Please Help
  • Dontknowchit
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
Dontknowchit
