Went to the track yesterday
seems like there is room for improvement. you should have a little more power then me with those heads. i know my car could go 12's if i did not sprin first and second. im still on street tires. where do you shift at? i guess thats one of the advantages of no snow down here. the track only closed for 2 weeks around christmas time and opened back up on jan 4
Well, I think you could pull more MPH with those heads.
As your car sits now, a ~1.8 or so 60' should get you a 12 second slip...
However, your car is probably underinjected at this point, and I think that:
Soon to add
24lb Injectors--75mm MAF sensor--Custom Chip
will help you alot...you should probably be trapping at or better than 106 after this, going by what others have done with similar setups.
