Wet Weather Startups...
  • Thread starter Thread starter Jon350
  • Start date Start date Jan 27, 2004
Jon350
201
SoCal
Jan 27, 2004
  • Jan 27, 2004
I hate starting the stang up in the rain. Say for intance i leave it outside overnight in the rain (i know, i hate the idea too), and try to start it up in the morning all it does is turn over forever, sputtering once or twice trying to come alive. Now, i've checked to see if water entered the carb., distributor, ignition coil, or spark plug wires, but not a drop could be found (the msd 6AL is in the mail).....I think it could be that the spark plugs simply aren't getting enough juice.
My question is, Is there anything known for resisting electricity when it's wet/damp in the ignition system? If i drive in the rain and let it warm up then turn the motor off I have no problems cranking it back on, it only happens when it's been sitting for a couple hours in the rain. Where are the gremlins hiding?
1slyfox
128
Concord, MA
Jan 28, 2004
  • Jan 28, 2004
Have you checked plug gap?
Jon350
201
SoCal
Jan 28, 2004
  • Jan 28, 2004
Could outside water really affect plug gap?...or what's the correlation your making here that i'm missing? The motor starts up fine in freezing weather if it's dry....it starts fine any other time except in heavy rain..
RGS0907
429
New Jersey
Jan 29, 2004
  • Jan 29, 2004
I'd say that it's your cap and/or wires. They are affected big time by moisture. Another (less likely) possibility is that if you have an automatic choke, the spring is going bad.
slapper
447
  • Jan 30, 2004
I would have to agree. I would check the cap very closely with a 10x magnifying glass for hairline cracks.
Also where the primary wire enters the distributor, ensure that the seal/grommet is in good shape. Plug wires should also be checked closely at both ends, and throughout their length.
Check the coil to see if it's wetting oil, or otherwise possibly impaired by moisture.
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
F
1986 mustang no start
  • foxyjamss221
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 13, 2025
foxyjamss221
F
  • brandyn200
  • Jun 20, 2026
AeroCoupe
