I will be buying new heads sometime in the near future and i am unseure of what i wanna go with. i know it will be an AFR head but i dont know between the 165's and the 185's. My combo is a balanced 306 w/JE/srp flat tops,trick flow street heat (eventually will go to track heat/systemax) 1.6 rr's,24'lbers, 76mm C&L, 1 3/4 longtubes, and im gonna go with a steeda #19 for emissions reasons. Last season this combo with a comp xe 274 cam, ebrock performers w.56 cc chambers (angle milled) cleaned up ports and worn out valve guides put out 285 rwhp w/4-500 miles on the shortblock.I want to make over 300rwhp this year which i had thought would have happened last year but i want to do it emissions legal this year. Also next year i will be adding an S-trim or P1sc and will run around 10-12 lbs. Which head to go with? the 165's or 185's? I know i will loose a lot of lower end with the 2.02 valve's on the 185's but will they be better for my future blower combo? Thanks to everyne in advance.
185's are too big for that setup stick to 165's and love the torque.
