  • SN95 4.6L Mustang Tech
what all is inside the pumpkin
  • Thread starter Thread starter Torinalth
  • Start date Start date Jun 16, 2005
T
Torinalth
952
Clayton NC
Jun 16, 2005
  • Jun 16, 2005
i have some horrid noise inside the pumpkin and am thinking of just tearing everything out and replacing it. i know the differential will be replaced with an eaton posi, ring and pinion (3.73), getting the pinion seal, and the connector from the driveshaft to the pinion that ataches to the other side of the U joint, and thinking axles just to be safe. is there anything else i need? oh, also getting the BBK girdle so i can get the drain and fill plugs
is there anything else i need to get to replace everything inside?
Torinalth
Stang35
22
Alabama
Jun 16, 2005
  • Jun 16, 2005
Just make sure you change the blinker fluid
A
artificial HP
89
  • Jun 16, 2005
I'd get the master install kit for the ring and pinion. That way you dont have to nickel and dime all the pieces like the crush sleeve, etc....
T
Torinalth
952
Clayton NC
Jun 16, 2005
  • Jun 16, 2005
does FRPP sell the blinker fluid?
i'll look into the master kit, i think stangsuspension.com sells that kit. aside from the kit, differential, ring/pinion, and axles is there anything else inside the casing that would need replacing?
Torinalth
9646gt
595
Holloman AFB,NM
Jun 16, 2005
  • Jun 16, 2005
MT1083
1,033
Charlotte, NC
Jun 16, 2005
  • Jun 16, 2005
Depending on your mileage you might want to replace axle bearings and seals while your in there.
T
Torinalth
952
Clayton NC
Jun 16, 2005
  • Jun 16, 2005
ahhh good, more items to add to the growing list.... acutally.... if i go with 31 spline axles, i will hvae to do this anyhow, right? but i'll add axle bearings and seals to the list.
Torinalth
C
cougar694u
145
San Antonio, TX
Jun 16, 2005
  • Jun 16, 2005
Torinalth said:
ahhh good, more items to add to the growing list.... if i go with 31 spline axles, i will hvae to do this anyhow, right?
I don't believe so, I think only the spline area of the axle is thicker, and not stepped as much as 28's. It's good to change the anyway.
You may want to change the pneumatic fluid, though
MT1083
1,033
Charlotte, NC
Jun 16, 2005
  • Jun 16, 2005
The axle bearings don't HAVE to be changed, but I just changed mine while I was in there for peace of mind.
twogts4us
4,188
12
79
Dunedin, FL
Jun 17, 2005
#10
  • Jun 17, 2005
  • #10
seeds and a bunch of mucky orange crap
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
M
2001 evap/heater core questions
  • mnky99
  • Sep 3, 2025
SN95 V6 Mustang Tech Sep 3, 2025
mnky99
M
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 23, 2026
JH96GT
