What all is needed for cobra/mach 1 brake upgrade??
On the front, the caliper brakets are built in the caliper, you may need hoses. I am not sure if the GT ones will fit the Mach 1 caliper.
As for the back I think you need quite a bit of stuff. I know the cobra rear brake kits come with a bunch of crap.
front= caliper/bracket, banjo bolts, lines (you have rotors)
rear= cobra caliper mounting bracket, maybe anti moan bracket. (you have rotors/calipers)
also for rear you will need cobra brake pads unless your GT pads are worn down some (thicker rotor)
-Front Calipers - pick your colour and logo from FRPP
-Rear Calipers - if you go with black fronts you can use your GT rears, if not get M-2320-R
-Rear Brake Bracket Kit - M-2300-M
-Front Discs and Cobra Hoses - M-2400-C
i've a deal on cobra/bullit/mach1 front caliper.
if i want to install it, on my 99 GT
i need to buy?
1. the caliper
2. 13" rotor
3. brake hose
the caliper is bolt-on? i've done some search and some body says that i need a braket, and others say that the braket is built-in the caliper.
i'm a little confused :(
i need to buy?
1. the caliper
2. 13" rotor
3. brake hose
the front caliper is a complete unit with the bracket attached, the rear would need a seperate mounting bracket. And i think 99 up GT hoses will work ok. I had to replace my hoses/banjo bolts but i have a 96 which has single piston fronts.
lets not forget the stock spare does not fit, and man is that a long and costly journey. unless your willing to risk it or just call for a tow. i payed $98 for the cobra wheel and $145 for the tire that took a week to ship, special order. on a happy note the brakes kick butt!
If your front and rear tires are the same size you could swap a rear tire to the front and use your GT spare on the back still though!
