bnickel
i'm not 100% sure that the granadas are the problem as i've never had a set myself, but it definately sounds like the problem other people have had with them. i don't think the problem is with the height of the spindle but actually with steering arm angle or something, maybe slip angle or ackerman angle but i'm pretty sure it is with the slip angle. check out www.gt350clone.com and read about Bob's experience with the granadas. i would also do what hack suggested and pull the springs and move the suspension up and down on both sides to see if it binds anywhere, if it does then that is likely where your problem is, if not then i would suspect the spindles even more. the only way to fix the problem with the granada spindles that i know of is to replace them with a unit designed for the mustang. you might also check out www.corner-carvers.com and do a search for granada spindles or just granada and you'll find a lot of info on them, just be careful if you post a quaestion those guys can be pretty brutal with their responses. i have really bad back problems too,(degenerative disc disease, fibromayalgia and osteoarthritis) so i completely understand what you're saying, however the idea of the adjustable shocks on the street is to set them where you have a good balance of handling and ride and then leave them there, that would require getting under the car a few times but once you have them set you're done. if you do go that route i would start with the middle adjustment front and rear and the go stiffer in the front and softer in the rear and then vice-versa to get an idea of what suits you best, but i imagine you would prefer stiffer in the front and softer in the rear, at least that's what my back likes anyway
a larger front bar may help some as well but if it is the granada spindles giving you problems a larger bar may make it worse.
