What are some good, inexpensive rear control arms?
Kerpal
400
I think my rear axle may have shifted about an inch rearwards on the passenger side due to control arm bushing wear... an alignment shop tried to tell me I had a bent axle housing, but it seems to me that bad bushings would be much more likely...? I'm going to get a second opinion, but I'm pretty sure I'll just need new bushings, which makes this an ideal time to replace the rear control arms.
I was thinking I'd go with Ford Racing uppers since a lot of people seem to reccomend them over ones that use poly bushings. Are these a good choice?
Who makes a good quality non-adjustable LCA that isn't too expensive? Are something like Mac or Blue Oval Industries (eBay) arms any good, or should I look at something like Steeda's steel LCAs, or some UPR's?
I'm trying to stay in the $225 or less range for uppers and lowers.
The other question I had is, should I get some poly bushings for the axle-side upper mounts? I don't understand why no one seems to include these with their UCA's...
pro3 is pretty cheap, look at the parts section in stangnet, they have them. UPR is also pretty cheap but I would never buy upr, not to mention they look quite like the team z motorsports control arms :scratch:
Look for control arms with rubber bushings or sperical bushings in you can. The poly bushings can be too hard and cause the rear end to bind in corners. For straight line driving they are OK.
The D&D arms are very good. They have delrin bushings that are much better and last longer than polys.
Steve, you may have to clarify a little. I don't see how a rubber bushing is better than a poly...is that a typo? The rubber causes deflection and suspension bind much worse than polyurethane....by your same logic a spherical, or solid aluminum bushing, would be the worst since it is much much harder. I think it was a typo.
I have the D&D arms and I like them, if you want to be cheap and have accesse to a welder, just box up the stock stuff and put some new bushings in (make sure it is afterward so you don't cook the new ones) don't forget to make a spot for the rear swaybar on the lowers.
Paint them up nice and they will end up looking just like the macks.
If I was to do it again, I would weld up the top arms and put in something like a lakewood lift bar in the lower to help the instant center.
Or I would weld up the top and relocated the top mounts on the car to fix the IC and then get a lower arm that you can adjust the height.
srothfuss said:
This is a good site to read up on: http://www.miracerros.com/mustang/t_suspension.htm
The reason that I say rubber is better than poly (without a sperical end) is because of "snap steer." The car will drive better with poly, but at the limits of cornering there is less forgiveness in poly [verses rubber] so the rear end comes around a lot faster....
I can't exactly argue with that except that the forgivness in the rubber is slop in the suspension and can make a car a lot less predictable as it won't always act the same way. None the less I will read the article. If rubber were better I would imagine that Steeda, Saleen, MM, Griggs, D&D, Lakewood, BBK.....would use rubber. I don't mean any disrespect. The problems associated with rubber are why he's looking for a different set of arms.
This is copied from MM's website: They can say it better than I can.--
Rear Lower Control Arms
Improve traction and handling with Maximum Motorsports Rear Lower Control Arms. Replacing the stock rear lower control arms, and their soft rubber bushings, with MM Rear Lower Control Arms will keep your tires firmly planted on the road.
What sets MM Rear Lower Control Arms apart from all the rest?
It’s the engineering expertise we put into our unique bushing designs. Instead of simply making control arms the same way as everyone else, we first analyzed the Mustang’s rear suspension geometry, and then designed control arm bushings to provide what is needed to improve traction and handling. The superior design of MM rear lower control arms increases traction, without the poor handling characteristics commonly caused by most other aftermarket control arms.
The rear control arms connect the rear axle housing to the chassis. All of the forces that accelerate the car, as well as the braking loads, pass through the rear control arms. In stock form, the deflection of the rubber bushings prevents the rear axle from maintaining its correct position under the chassis, leading to instability from rear steer. During acceleration, the rear tires push the axle forward, which in turn moves the car forward by pushing on the rear lower control arms. Replacing the rear lower control arms with MM control arms will improve traction and handling primarily because of the elimination of the overly compliant stock rubber bushings. With MM rear lower control arms, the properly designed bushing mounted in a stout tubular arm keeps the axle correctly positioned under the chassis. Traction and handling are both improved because the axle does not move around in an unpredictable manner.
Most aftermarket rear control arms use hard 2-piece urethane bushings, Delrin bushings, or steel bushings. Those types of bushings do not allow the angularity needed for the Mustang’s suspension to articulate freely. The resulting suspension bind causes the rear tires to break loose very easily. Suspension bind not only causes poor handling and poor traction, but it also causes damage to the torque-boxes. As the attachment points on the chassis for the rear control arms, the torque-boxes can suffer greatly from the abuse of poorly designed control arm bushings. After all, the torque boxes are only made of folded sheet metal.
Stop wheel hop
Ford’s solution for reducing wheel hop was the addition of the quad shocks (the two horizontal shocks mounted behind the rear axle). They reduce wheel hop by dampening axle wind-up. Axle windup is caused by two independent deflections: the control arms, and the rubber bushings. Deflection of the control arms is eliminated because the MM arms are over three times stiffer than the stock control arm. Deflection of the soft stock rubber bushings is eliminated by our unique bushing designs. These designs are the result of extensive motion analysis of what actually occurs when the rear suspension moves over bumps, and during body roll. Installing MM’s rear lower control arms eliminates the primary cause of wheel hop, which is the deflection of the stock lower control arms and their bushings. While there are other factors besides the compliance of the control arm bushings that cause wheel hop, the MM arms usually reduce axle wind-up enough to allow removal of the factory quad shocks.
Good Research is the Basis of Good Engineering
The concept of wheel rate is similar to that of spring rate. But, to put it into simple terms, the wheel rate is measured at the wheel, not at the spring. Poorly designed suspension components can prevent the control arms from articulating properly during bump and body roll, and therefore cause suspension bind. This suspension bind will cause the wheel rate to increase unpredictably, adversely affecting handling.
To analyze the geometry involved, Maximum Motorsports used a full-scale mock up of the rear suspension. When we tested other aftermarket control arms, we found that most use bushing designs that actually cause an increase in suspension bind, compared to a stock control arm! Control arms that had hard urethane bushings at each end increased the wheel rate by 400%! For example, as little as a 10% increase in rear wheel rate will have a noticeable effect on the handling balance of a car, because the rear cornering grip will be noticeably reduced.
So, why does the wheel rate increase? In the Mustang’s rear suspension design, whether it is still the stock 4-link suspension design, or has been modified to a Torque-arm or three-link design, the control arms do not simply pivot. The arms also move sideways, with an angular motion (relative to the pivot axis). If that angular motion is restricted because of a poor bushing design, the suspension will bind. While some aftermarket control arms may seem to improve performance because of reduced bushing compliance, it is only improved to a level slightly higher than the stock control arms. Once the car is pushed past that level, the increased wheel rate from the suspension bind will cause unpredictable handling– not to mention damage to the torque boxes.
To avoid that nasty situation, the two different bushing configurations of both the MM Heavy-Duty and Extreme-Duty Rear Lower Control Arms allow the necessary freedom of suspension articulation, while continuing to positively locate the axle in the fore-and-aft direction.
MM offers two different types of rear lower control arms: Heavy-Duty and Extreme-Duty. The difference between the two is the bushing configuration. The Heavy-Duty arms are suitable for cars with moderate horsepower levels that are not drag raced. We recommend the Extreme-Duty control arms for any car that is drag raced, and any car with the higher horsepower levels that come with superchargers, larger displacement engines, etc.
To adjust, or not to adjust...
Both our Heavy-Duty control arms and our Extreme-Duty arms are available in two basic styles: Non-adjustable, or adjustable for ride height. These two styles are available with several different options for spring perches and swaybar mounts. This ensures that we have exactly what you need for your car.
Non-adjustable Control Arms
Non-adjustable arms are available with a fixed-position spring perch that maintains the same ride height as a stock control arm, or without any spring perch at all, for coil-over applications. These control arms are available with mounts for a factory-style rear swaybar, or without any swaybar mounts, for use with MM's Adjustable Rear Swaybar.
Adjustable Control Arms
The easy adjustment of MM's Adjustable Control Arms allows raising the rear ride height by up to 2 inches, or lowering it as much as 1 inch. A heavy-duty weight-jack bolt, similar to those used in NASCAR, makes this possible. The spring perch design allows easy ride height changes, with the car still on the ground. Road racers and autocrossers can set not only the ride height, but also corner weights, for optimum handling. A car can be fully loaded up with gear for a road trip, and then have the rear ride height adjusted back up to normal, to avoid bottoming out. These control arms are available with mounts for a factory-style rear swaybar, or without any swaybar mounts, for use with MM's Adjustable Rear Swaybar.
wow thats alot to read. the lakewood lowers have kinda adjustability because they have 2 mounting locations. it changes your pinion angle. I set it up on the lowest mounting spot. I believe the instructions said that that was the more traction set up.
what srothfuss (dude that name is brutal) said is good advice. I am in the market for control arms right now as well and i think i am going to go with the pro3i's because that share an identical design to MM with that 3 piece bushing. Poly bushings are nice for eliminating slop but they can often be loud and can lead to twitchy handling. The uppers are not quite as crucial...i think i might just weld up the stockers for a cheap/effective alternative. good luck
i got the upr upper and lowers as a kit for 169 at ffw last year and i think they work awesome. whats the deal with every one bashing upr i got there rear upper and lower control arms and their front tube k member kit with the coil over conversion and thought the price and quality to be really good, but all i hear is people bashing them. what gives
imo upr is only "great" because they copy everyone elses great ideas.
