What bulbs goes where?
This is from sylvania's website: http://www.sylvania.com/ConsumerProducts/AutomotiveLighting/LampReplacementGuide/AutoLRG-Results.htm
1990 FORD Mustang
High & low beam headlamp
9004
9004SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9004ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9004XV XtraVision Halogen Upgrade: Up to 20% Brighter
9004CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
9004LL Long Life Halogen Upgrade: Lasts two and a half times longer
Parking light
3157A
3157AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
3157NALL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal
3157A
Rear turn signal
1156
1156LL Long Life Upgrade: Up to twice the life of the standard lamp
1156A
1156AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
Tail light
3157
3157LL Long Life Upgrade: Up to twice the life of the standard lamp
Stop light
3157
High mount stop light
912
Fog/Driving light
H3-55W
H3ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
License plate
168
Back up light
3156
3156LL Long Life Upgrade: Up to twice the life of the standard lamp
Front sidemarker
916NA
Rear sidemarker
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Ash tray
161
Glove box
194
Map light
1816
Dome light
1816
906
Step/Courtesy light
194
74
Trunk/Cargo area
98
Under hood light
906
Instrument-general
161
1816
194
Hi-beam indicator
194
Seat belt indicator
194
Brake warning
194
Automatic transmission indicator
1816
Directional signal indicator
194
____________________________________________________
The applications presented in this replacement guide have been compiled using the best information available from the vehicle manufacturers at the time of your search. This guide is intended for general information purposes only, not to be construed as any type of warrantee as to any particular application. For specific applications the vehicle owner's manual should be consulted.
hunh!!!:shrug: wtf is that! looks like a spaceship!
anyways its getting too late now but if u really need i can go check tomorrow. pretty sure that the trunk (inside) and dome lights are the same, and under hood bulb is the same as the license plate bulbs. thats all i remember. thats not what the previous post is suggesting though...?????:shrug: dont know if its manufacturer specific. my local parts store had no prob finding the right ones though.....
There are different bulbs that will work as long as they are 12 volt and have the same base. This does not mean they will have the sameoutput or fit in every application. The license plate lights are 168's, but I usually use 194's, the engine light is a 906, but a 194 will fit. The problem with using a 194 under the hood is it is a smaller bulb and does not have the same light output.
Manufacturer does not change the # of the bulbs, they are a set #. Hence that is why you can buy a 9004 bulb from any mfg and have the same bulb.
We both got white stangs but yours is nicer!!
Anyway, yea that would be awesome if you could find out if the trunk and dome are the same and what # bulb they are.
Thanks alot
The trunk/hatch and the dome light are not the same bulb. The hatch bulb is a long bulb with contacts on each end. The dome light has a push in connection. Not to be rude, but do you have your car with you? Its not that hard to go out and look or pop open a cover to see what bulb is in there. Generally the bulb # is even printed on the bulb. Maybe I just don't see where your coming from on this. Good luck:flag:
